Analysis to figure out how fast Greenland is melting
by Mari N. Jensen on 9 Jul 2017
Taken from the International Space Station in 2016, this picture of the southern tip of Greenland shows the island’s vast ice sheet fringed by glacier-carved fjords. If all Greenland’s ice melted, sea levels would rise by about 7 meters (23 feet). NASA http://www.nasa.gov
A new analysis of Greenland's past temperatures will help scientists figure out how fast the island's vast ice sheet is melting, according to a new report from University of Arizona atmospheric scientists. The ice sheet has been shrinking since 1900 and the yearly loss of ice has doubled since 2003, other researchers have shown. The accelerated melting of the Greenland ice sheet is contributing to sea level rise.
The glaciers and ice sheet of Greenland cover a land area greater than the European countries of Germany, France, Spain and Italy combined. If all Greenland's ice melted, sea levels would rise by about seven meters (23 feet). Figuring out how fast the island's ice has melted and will melt in the future requires knowing the past and the present surface air temperatures, according to UA researchers J. E. Jack Reeves Eyre and Xubin Zeng.
'Greenland is particularly important to global climate change because it has the potential to cause a big change in sea level,' lead author Reeves Eyre said. 'Knowing how it's going to change over the next century is important.'
Calculating an average yearly surface temperature for the whole of Greenland is difficult. During most of the 20th century, the only weather stations were along the coast. There was no network of weather stations in Greenland's interior until 1995. Other groups of researchers have used combinations of weather station readings, satellite remote sensing data, statistical analyses and climate models to calculate the island's annual surface temperatures back to 1901. However, the results of those analyses disagree with one another substantially.
How Greenland's massive ice sheet will respond to future warming is not well understood, said Zeng, a UA professor of hydrology and atmospheric sciences. By combining the best two of the previous analyses, the UA study provides the most accurate estimates of Greenland’s 20th-century temperatures, said Reeves Eyre, a doctoral student in the UA Department of Hydrology and Atmospheric Sciences.
The finding will help improve climate models so they more accurately project future global climate change and its effects. 'That's why we look at the historical period — it's not about the history, it's about the future,' said Zeng, who holds the Agnese N. Haury Endowed Chair in Environment.
Reeves Eyre's and Zeng's research article, ' Evaluation of Greenland near surface air temperature datasets,' was published online July 5 in the open-access journal The Cryosphere.
NASA, the U.S. Department of Energy and the UA Agnese Nelms Haury Program in Environment and Social Justice funded the research.
Knowing Greenland's past temperatures is important for improving climate models, because scientists test regional and global climate models by seeing how well they predict what the climate was in the past. Previous analyses of the island's past temperatures came up with contradictory results: Some said the 1930s were warmer than present, while other analyses said the opposite.
To find the best estimate of 20th-century temperatures, the UA scientists compared 16 different analyses. The UA team compared more datasets covering the period 1901 to 2014 and used more information from weather stations and field expeditions than previous studies.
'We are the first to bring all those datasets together,' Zeng said.
To avoid bias from lumping temperature data from different elevations, Reeves Eyre and Zeng divided the temperature data into three categories: data from coastal regions, data from lower than 1,500 meters (about 4,900 feet) and data from above 1,500 meters.
The coastal regions of Greenland are ice-free year-round, whereas the glaciers and ice sheet at the intermediate elevation melt some in the summer but refreeze in the winter, Reeves Eyre said. The ice sheet and glaciers at the intermediate elevations are shrinking a bit each year because temperatures are increasing.
Above 1,500 meters, the ice generally does not melt and may even gain mass, he said. However, the bit of ice gained at the highest elevations does not offset the loss of ice at the lower elevations. The UA study resolves the discrepancies among the other analyses and provides the best estimates of Greenland's past temperatures.
'The combination of the MERRA2 and GISTEMP (analyses) gives the most accurate results over the 20th century,' Reeves Eyre said. 'Putting them together is more than the sum of the parts. Neither of them individually can do what both of them together can do.'
Although some previous analyses suggest the 1930s were warmer than it is now, the UA analysis shows that current temperatures are warmer than the 1930s. The long-term trend for Greenland's ice sheet appears to be for ever-higher surface temperatures, he said.
'By studying a wide range of available data and combining two of the best data sources, we've come up with a combination that best represents the whole distribution of temperatures over Greenland from 1880 to 2016,' Reeves Eyre said. 'Using this dataset is the best way to evaluate climate models and their projection of temperature change over Greenland.'
For more information visit website.
Hyde Sails 2022 One Design FOOTERCrewsaver 2021 Safetyline FOOTER2024 fill-in (bottom)
SSCA 2024 Chesapeake Bay GAM
Taking place in September at Maryland Yacht Club Join us for the Seven Seas Cruising Association's 37th Annual Chesapeake Bay Cruisers' Conference and "GAM" from September 27 through September 29, 2024.
Posted on 17 Apr
Chatting with Denis R., currently the owner of a J/99 and soon to be of a J/112E We asked some questions to Denis R., currently the owner of a J/99 and soon to be of a J/112E. He shares his feelings about why he chose the J/99 and why he is staying in the family with his next boat, the J/112E.
Posted on 17 Apr
His Royal Highness Crown Prince Haakon of Norway has agreed to become a goodwill ambassador His Royal Highness Crown Prince Haakon of Norway has agreed to become a goodwill ambassador for Statsraad Lehmkuhl's next major expedition, the One Ocean Expedition 2025-2026.
Posted on 17 Apr
At all the key boat shows this Spring As the boating community eagerly gears up for the season ahead, the team at Ancasta has an impressive itinerary and line-up for upcoming shows and events across the UK and Europe.
Posted on 16 Apr
Maintaining Banyandah is a labour of love Maintaining Banyandah, the vessel we launched in 1974, has become ingrained in our very being. It's not just about keeping her seaworthy; it's about nurturing a connection that runs deeper than the ocean itself.
Posted on 15 Apr
S/V IdaLina sank earlier this week some 300 miles east of the Marquesas S/V IdaLina, an Arcona 460, sank earlier this week some 300 miles east of the Marquesas. IdaLina was the home of two Swedish OCC Members, Ingmar Ravudd and Katarina Bääth.
Posted on 15 Apr
After a member of the public called the sawfish hotline Mote Marine Laboratory and the Florida Fish and Wildlife Conservation Commission responded to a distressed smalltooth sawfish after a member of the public called the sawfish hotline and reported the animal swimming in circles in Cudjoe Bay.
Posted on 14 Apr
Getting ready for the departure towards the Great Barrier Reef and Indonesia Teatime and her crew, Domi, Anna, Boróka, and Katalin, embarked on their journey from Croatia in late June 2020.
Posted on 13 Apr
A sail rally to North Sound, Hobie Cat racing at the Bitter End Yacht Club, a dock-tail contest What started in 2012 continued this year with 13 boats and more than 50 attendees, coming from all over the United States and Canada.
Posted on 12 Apr
SSCA 3rd Annual Bahamas Gathering
Filling the harbor for days of cruiser and community fun! We filled the harbor for days of cruiser and community fun! This was a 'come and join us,' no-attendance-fee event.
Posted on 12 Apr
