Southern Spars - North Technology
How to read your charts – Seven signs of danger
by skippertips.com on 18 Apr
Recognize these seven danger chart symbol groups to keep your small cruising boat safe and sound. Spoil areas can contain any type of danger, thus it lies center-stage. SkipperTips.com
Could you glance at any nautical chart in the world and tell the difference between a submerged wreck that's safe to sail across and one hidden just below the surface? Read on to learn the most vital chart symbols you need to know for chart navigation safety.
Learn to recognize rocks, wrecks, and obstructions at a glance. Below, you will find the seven most common groups of hazard chart symbols. There are many more, but you will run across these seven groups time and again.
1. Rocks
Note how the basic rock symbol looks like a plus sign. This means a rock that's beneath the water surface all the time. A symbol that looks like an asterisk means the rock will uncover (become visible) at low tide. A plus sign with dots in the corners means the rock lies just beneath the surface--or awash--even at low tide.
2. Islets (small islands)
Small islands--called 'islets'--are common in the Bahamas, Caribbean, and Pacific. Islets surrounded by a solid line are visible at all tidal stages. A number indicates the height of the rock above high water datum. Islets surrounded by a wavy, squiggly line with greenish tinting inside will cover and uncover with the tide. At higher tides, the islet will be covered. An underlined number indicates how much of the rock will be visible only at low tide.
3. Breakers
Breakers form when ocean swell meets a sea bottom that's only one to two times their height. For example, if a 2 foot swell travels over a bottom 2 to 4 feet deep, it will break. Breakers are dangerous to any small craft. They can cause loss of rudder or propeller control. Stay clear of any breaker symbol like that shown in the illustration. You may see the abbreviation 'Br' used without the symbol.
4. Coral Reefs
The world's most popular cruising grounds--Bahamas, Caribbean islands, and Pacific atolls--also contain some of the most dangerous waters. Study your navigational chart with care and look for the 'Co' abbreviation close to any rock or islet symbol.
5. Obstructions
Easy to miss on a nautical or electronic chart display, obstructions can cause damage to propellers, shafts, and keels. Many charts use only an abbreviation 'Obstn' to warn mariners. Dots around a circle mean an unknown hazard lurks beneath the surface. Tiny enclosed circles could be broken stumps, old piling remnants, or submerged poles and posts.
6. Wrecks
Fish-bones and sunken hull illustrations make up the most common wreck symbols. Fish-bones without dots are safe to sail across. Cartographers put these on charts to warn commercial fishing trawlers not to drag nets and to caution ships not to anchor. Give fish-bones surrounded by dots or hull symbols a wide berth to avoid hull damage.
7. Spoil Area
Deadlier than the plague, identify, highlight, and stay clear of dashed outlines with descriptions like 'Spoil Area', 'Fish Haven', 'Fish Traps', or 'Dumping Ground'. Ever wonder where all those old cars and trucks, building material, or garbage goes? Now you know! Spoil areas never show soundings because depths change all the time.
Other Chart Abbreviations You Need to Know
Familiarize yourself with the danger abbreviations used with or without the symbols described above. Study these until you know them at-a-glance:
Rk, R or Rks - Rock or Rocks
Hk or Wk - Hulk or Wreck
Obstn - Submerged Obstruction
Co - Coral
Foul - Foul Ground
These additional abbreviations may be found alongside any danger symbol, or they may stand alone. For instance 'Shoal Rep' means that shallow water was discovered at that position by a mariner, but it has not been surveyed. Stay clear of any area on your navigation chart marked by these abbreviations.
PA - Position Approximate
PD - Position Doubtful
ED - Existence Doubtful
Rep - Reported
SD - Sounding Doubtful
Now you know how to identify any of the seven danger group symbols on any sailing chart in the world. Use these chart navigation secrets to give you the edge and keep your crew safe and sound wherever you choose to cruise.
This article has been provided courtesy of the CruisingOdyssey.
Barz Optics - San Juan Worlds Best EyewearPredictWind.com 2014North Technology - Southern Spars
May Rendezvous – Sail-ebrate Canada 150
Come for the fun, the food, the camaraderie, the splash of red-and-white (flags, sails, attire, bunting, decorations) Mark your calendar for May 20 – 22: the May Rendezvous, Poet’s Cove, Pender Island! Arrive Friday evening or anytime Saturday before the 1600h Happy Hour. The official Rendezvous agenda starts at 1600h on Saturday. Come for the fun, the food, the camaraderie, the splash of red-and-white (flags, sails, attire, bunting, decorations, etc) and the music!
Posted on 25 Apr
World ARC in the atolls of the Tuamotu
The departure to the Tuamotu archipelago had a good start, with privilege of crossing paths with visit of vessel HOKULEA The departure to the Tuamotu archipelago had a good start, with the privilege of crossing paths with the visit of the Hawaiian traditional sailing vessel HOKULEA, in Nuku Hiva. The fleet had a touch of our counterparts from the past, whom populated the whole Pacific Ocean in sailing vessels, guided by their knowledge of the stars and the sky, the movements of the sea
Posted on 25 Apr
Debbie says the 8thP with Insurance is Patience (Pt.II)
We’re back to keep exploring the nature of TC Debbie and how she came to tell us about the eighth P of insurance We’re back to keep exploring the nature of TC Debbie and how she came to tell us about the eighth P of insurance. We looked at what it was like to come into a disaster zone and now we see the evidence of those that did the right thing, and how the area is already on the road to recovery.
Posted on 25 Apr
The best laid plans of mice and sailors...
We knew that buying a boat wasn’t going to be easy; our budget was tight, and our needs specific... We knew that buying a boat wasn’t going to be easy; our budget was tight, and our needs specific, even if both of us spend our working days surrounded by boats, and undertaking complicated negotiations. But neither of us were prepared for the emotional rollercoaster that awaited us, and the many disappointments that we would have to overcome in our search.
Posted on 24 Apr
Coral reefs fight rising seas, leaving people at risk
Caribbean/Hawaii researchers found sea floor eroding in all five places and reefs cannot keep pace with sea level rise. In the first ecosystem-wide study of changing sea depths at five large coral reef tracts in Florida, the Caribbean and Hawaii, researchers found the sea floor is eroding in all five places, and the reefs cannot keep pace with sea level rise. As a result, coastal communities protected by the reefs are facing increased risks from storms, waves and erosion.
Posted on 22 Apr
Flares and distress signals
Visual Distress Signals are part of your boat's safety equipment. Check them before you leave harbor for condition Visual Distress Signals (V.D.S.) are part of your boat's safety equipment. Check them before you leave harbor for condition and if they have an expiration date, be sure they are current. Their intended purpose is to summon help should the need arise and should be displayed only when immediate or potential danger exists. Visual distress signals can only be effective when someone can see them.
Posted on 21 Apr
Race for Water will stay in Madeira for three days
After beginning its five-year Odyssey on April 9, the vessel, Race for Water, arrived in Madeira on Thursday, April 20 This first stopover will allow the crew to make a preliminary assessment of the energy mix and review the first tests with the kite on this ambassador vessel of the Race for Water Foundation.
Posted on 21 Apr
Chilling out in Carriacou
Carriacou is a delightful backwater in the Caribbean, peaceful and relatively undeveloped, with beautiful beaches We feel like we earned this place - after sweating it out in Trinidad for several months, Carriacou is a delightful backwater in the Caribbean, peaceful and relatively undeveloped, with beautiful beaches. The local population is only 8,000 folks, a mix of African, East Indian and European decent. It’s a simple place, where people greet you on the bus and welcome you to their island.
Posted on 20 Apr
The big question
In October 1999, we left our sailboat in the South Pacific and returned to enjoy a Canadian winter. In October 1999, we left our sailboat in the South Pacific and returned to enjoy a Canadian winter. A few friends have expressed curiosity about our nautical lifestyle, especially the long passages: “What do you do all day?” they ask: Two people, alone in a small boat on a large sea for 3000 miles, 24 hours a day, no anchorages, restaurants or spas in between.
Posted on 20 Apr
A 180 degree turn
After a wonderful Bon Voyage party, our family came down and tossed off our bowline. There was so much excitement After years of dreaming and planning, we are finally at the ‘Doers’ stage. In September, our Alden 44, Lemanee, and her crew of three set sail southbound. We were heading to San Francisco via Roche Harbour and Neah Bay. After a wonderful Bon Voyage party, our family came down and tossed off our bowline. There was so much excitement and pride at all we had accomplished.
Posted on 20 Apr
