X-23294 Accon – Stylish pop-up LED bow lights save space
by Accon Marine on 19 May 2017
X-23294 Accon – Stylish pop-up LED bow lights save space Accon Marine
Boat designers have long wrestled with sometimes conflicting goals of creating clean, smooth lines while maintaining everyday practicality.
By folding down flush when not in use, Accon Marine's Pop-Up® LED bow lights achieve this balance. They keep the foredeck free of unsightly protrusions to preserve a boat's graceful profile without sacrificing functionality.
The only Pop-Up LED lights on the market, the 210 and 211 models are US Coast Guard-approved to two nautical miles. They meet the 72 Colregs standard for nautical lighting and are type-approved by the National Marine Manufacturers Association. The footprint of the 210 is approximately 102mm W x 114mm L; the 211 is 89mm W x 135mm L.
Made from marine-grade 316 stainless steel, both lights mount with three stainless steel #10 screws. An installation template is included and an optional plastic cup prevents unwanted water runoff below deck. Accon Marine's 210 LED bow light is also available in a stud-mount model, which uses a 51mm stud to eliminate visible screw holes.
A video below shows how easy each light is to install.
If you want to link to this article then please use this URL: www.sailworldcruising.com/153912
