Midwinter hints and tips
by Jack and Jude 4 Aug 2018 14:10 UTC
Sailing is fun © Greggo
Hello from Northern NSW, where the balmy days feel more like summer than mid-winter, and are perfect to tackle a bit of boat maintenance. So, we thought we'd put up a few helpful hints for maintaining your vessel and gear.
For the many who have asked how Jude is recovering from her fall and broken wrist bones – she's fine, her wrist is nearly back to 100% but her ankle which was over extended and suffered severe bruising is still causing her pain. She's now out of the Cam Boot and to get full use of her ankle again she's right into a whole range of exercises set out by her physio to relieve the swelling. Even better news is that we're planning our next offtrack excursion – albeit this time we'll be carrying a wee bit less weight. With such wonderful winter weather, a week lost in the never-never enjoying Nature's wealth is calling like a siren.
Tips to Save Your Costly Running Rigging
By guarding against the five deadly enemies of all line: sunlight, dirt, salt, chafe, and shock, you can extend the life of any piece of marine rope and save replacement costs by doing just five simple things on a regular basis.
Wash and Dry Before You Stow!
Did you realize that nylon line–like those used for docking lines or anchor lines–can lose up to 15% of their strength when wet? Or that wet line, stowed in a dark, dank locker presents a prime breeding ground for mold and mildew?
Wash your anchor rode, cockpit sheets, and halyards with fresh water. Get into your anchor locker with a hose and spray it down. Do the same with your others lines or soak your ropes in a 20 litre pail of fresh. This will loosen up line-killing dirt and salt crystals. Then flake the line in alternate loops over a rail or your lifelines to dry them before coiling and stowing after they have dried completely. This can add years of life to any line and it will stay supple for sailing or marine knots. We always wash our lines when wintering Banyandah.
Keep Lines Under Tension
Halyards and Genoa or jib sheets must stay under constant tension to prevent fibre and strand breakdown. Lines that are too loose will shock and slack, which can weaken the line. Take care not to make lines too taut.
Some lines–docking and anchor lines–must have slack in order to perform their best. On the other hand, your super expensive sail halyards and sheets should be under tension. When sailing, re-tension your sheets and halyards once in a while to keep wear under control.
Make Leads Straight and True
Straight leads give you the best fair leads. You might have heard the sailing term "fair lead", which means the direction a line travels form one point to another. The straighter you keep the line, the less wear and tear on the fibers.
Keep this in mind whenever you need to thread a sheet through a block, or lead a line from the mast back to your cockpit, or set up your Genoa furling line between bow and cockpit.
Keep acute bends that change the lead of the line by 60 to 90 degrees to an absolute minimum. The more bend you put into a line, the more stress this places on the apex of the bend. Use straighter fair leads to pump life-blood into your lines and save on repair and replacement costs.
End for End Lines Once a Season
One of the huge jobs on olden day square-rigged ships was to end-for-end line once a year. This monumental task involved thousands upon thousands of metres of rigging. But it added years of life, and well it did because those big ships were at sea for years at a time, and the cost of line back then was astronomical.
Today, the cruising or racing skipper can use this same technique to add years of life to docking or anchor lines, halyards and sheets. And it's a lot simpler because you aren't dealing with so much cordage.
If using rope halyards, end for end the line will shift the wear point, just as it does for rope sheets. If anchoring on rope, just make the bitter end of the line the working end. Do this once a season. This end-for-end technique has been proven to extend the service life of anchor line, sheets and halyards by a whopping 50%!
Whip, Dip, or Tape Bitter Ends
The ends of your lines can fray and unwind to look like the head of a golliwog. Prevent this with whipping, where you wrap sail twine around the end. An easier temporary method uses 50 mm duct-tape. Wrap the tape tight, two to three times around the end, then use a sharp knife to cut through the line at the centre of the tape.
Or, make your own end-whipping dip. Dip at least 10mm of the bitter end into super glue. Any of these techniques are guaranteed to stop fraying and save you lots of money.
See more knots here.
Furlers – Friend or Foe?
After spending my first twenty years before the mast being bashed about by sailcloth and hardware while trying to stay aboard when changing sails, we invested in furling gear and a furling headsail. What bliss! No matter how hard the wind blew, I remained safe in the cockpit while reducing sail. Yippee! Never again did I have the arduous task of bagging stiff cloth or the problem of storing so many sails. But there are a few serious shortcomings with furlers and with winter's stronger winds upon us, let's review how best to manage them.
Furling sails are bulky. They create a lot of windage at the front of the ship that can make manoeuvring in confined spaces difficult, and when going to weather, their massive leading edge reduces performance. But it is while at anchor or hanging off a mooring that this extra windage can catch us unawares and cause damage or even loss of the vessel. The windage will cause your ship's head to be blown off the wind with the result that you may find the ship being blown one side to the other and this creates greater strain on your ground tackle.
Granddaddy of all problems
But the granddaddy of all problems comes when the sail has been loosely furled. In stormy conditions that ol' devil wind just keeps niggling at the loose folds, slowly tightening the sail around the spar to expose even more cloth that eventually has the clew working back and forth until the clew tears loose. Once set free, these sails self-destruct. Therefore, it is imperative that furlers are wound tight then finishing off with a minimum of three wraps of the sheets. Another thing to watch, the furling line must be maintained in good nick. If yours should break, you could lose your boat like what nearly happened to the bloke in this photo.
Read how this happened here.
Protect the sail
Furling sails spend most of their life exposed to the sun's UV and therefore most have a wrapper of sun resistant cloth to protect the sailcloth. It is important to furl the sail, but a problem develops as the sail ages because the area where the wrapper is attached to the sail is stiffer than the cloth and therefore the cloth works along that seam causing a weak point. We keep our eyes on this area as it is usually the first place the sail will fail.
Another thing we do when we leave Banyandah on a mooring for long periods is to remove the sail from the furler to lessen the yawing that can occur in gusty conditions. This makes our lady sit straight into stormy conditions thereby reducing the strain on our mooring system while at the same time it also extends the life of the sail.
This article has been provided by the courtesy of jackandjude.com.
Jack & Jude: A sea of beauty
We no longer visit what was once one of the world's seven natural wonders We first took our sons to explore the Coral Coast and Great Barrier Reef in the 1970s, when we were often the only vessel in an anchorage, and catching a fish dinner was so easy, we simply jumped over the side to pick which one. Posted on 4 Jul 2021
Jack & Jude: Closing the ring
Leaving Orford, our next few voyages were a treat It's a misty wet Sunday morning and I'm finding it hard to leave my cosy bunk after a long healing sleep. But I'm going to sit up, pull the doona up with me, and tell you about our great escape from Port Davey on Tassie's SW coast. Posted on 1 May 2021
Jack & Jude: Flying high at George Town
We've notched up plenty of sea miles since our last report Have to be swift. Tomorrow, we're sailing off into the never-never. Goodness knows when we'll have communications again. Next stop the fabulous Furneaux Group of islands in Bass Strait off Tasmania's Northeast tip. Posted on 24 Feb 2021
Jack & Jude: A year like no other
We cannot change the past, but the future is within our reach When you last saw a shooting star, did you make a wish? Or wonder what it's like to zoom towards Earth at a zillion miles a second? Well, it's something like that around here right now! Posted on 20 Jan 2021
Amateur radio expeditions to Spratly Islands
We took a group there in 1979 and nearly got blasted out of the water Way back when we were raising two children afloat, we earned our keep by taking brave Amateur Radio Operators to faraway mid-ocean pinpricks of land, where we set up base stations to talk around the world - sometimes contacting upwards of 30,000 stations. Posted on 10 Aug 2020
Jack & Jude: Reflections
An attack waiting behind thick Congo jungle In many ways living through this pandemic is similar to a life-threatening event Jack and Jude survived when just newly wedded kids looking for a place to live our lives. Posted on 31 May 2020
Jack & Jude: Voyage planning rules our lives
Sail through Hells Gate 250 Nautical miles in less than two days, from 10 AM Monday to 3 AM Wednesday, plus another hour to sail through Hells Gate after daylight. Posted on 7 Apr 2020
Four J's Around the World Trilogy
Break the boredom with a great book free from Jack and Jude Break the boredom with a great book free from Jack and Jude. Designed to cure the lockdown blues by reading family fun in exotic places overcoming life-threatening events. Posted on 26 Mar 2020
Where does the time go?
The years whisk past like autumn leaves in a gentle breeze When we sail across an ocean, each day will last a week - until we make port and then the voyage becomes a blip that's hard to remember. The years whisk past like autumn leaves in a gentle breeze. Posted on 5 Aug 2019
Marine Products Direct 2023 - Calypso FOOTERNorth Sails Performance 2023 - FOOTERHenri-Lloyd - For the Obsessed
