Study shows melting ice sheets could disrupt climate
by British Antarctic Survey 8 Feb 2019 06:29 UTC
Melting ice from Antarctica and Greenland will create climate disruption © Ella Gilbert
Water entering the oceans from melting ice sheets could cause extreme weather and a change in ocean circulation not currently accounted for in global climate policies, a new study published today finds.
The study, published in the journal Nature (7 February) led by Victoria University of Wellington's Antarctic Research Centre and involving an international team of scientists from Canada, the UK, Germany and the USA used climate models to simulate what might happen when water from melting ice sheets enters the Earth's oceans.
This is the first study to use highly detailed models of both ice sheets combined with observations of recent ice sheet changes from satellites. This combination creates more reliable and accurate predictions than has been achieved previously.
Lead author Professor Golledge from Victoria University of Wellington's Antarctic Research centre says:
"The level of melting is based on the amount of warming we can expect by 2100 if we continue with current global government policies. If nothing changes we are heading towards 3-4 degrees of warming above pre-industrial levels.
"With this level of warming, a significant amount of melt water from the Greenland and Antarctic Ice Sheets will enter our oceans. According to our models, this melt water will cause significant disruptions to ocean currents and change levels of warming around the world."
Co-author Kaitlin Naughten, a modeller from British Antarctic Survey says:
"Even with the Paris Agreement to combat climate change, there will still be some melting of the Greenland and Antarctic Ice Sheets. This will take thousands of years to fully play out, so predicting sea level rise as early as 2100 is actually a very short timescale, and a very difficult modelling problem. This study uses a new method to incorporate observations into ice sheet models, which narrows down the range of sea level rise outcomes we can expect.
"However, it's not all about sea-level rise. Melting ice sheets dump a lot of cold, fresh water into the oceans, and this affects the climate system. Deep ocean circulation in both hemispheres will be affected, as well as weather patterns across the globe. Most climate models don't consider these impacts, because they don't include ice sheets. Our study is one of the first to combine climate models with ice sheet models to get the two types of models to talk to each other."
The models used in this study show that in some areas of the world, ocean changes could lead to more extreme weather events and greater variation in temperatures. Deep ocean circulation in the north Atlantic Ocean will be significantly weakened by the influx of melt water, leading to warmer air temperatures in Central America, Eastern Canada, and the high Arctic, but reduced warming over north-western Europe on the other side of the Atlantic.
In the southern hemisphere, the models show that meltwater entering the ocean around Antarctica will trap warmer deep water below the surface. Instead of losing its heat to the atmosphere, this warm water will be able to access the Antarctic Ice Sheet and melt it from below.
Read the paper here.
This article has been provided by the courtesy of British Antarctic Survey.
The threat from Thwaites
The retreat of Antarctica's riskiest glacier Antarctica's Thwaites Glacier is retreating rapidly as a warming ocean slowly erases its ice from below, leading to a faster flow, more fracturing and a threat of collapse, according to an international team of scientists. Posted on 27 Jan 2022
Newly exposed Antarctic ecosystem
A mysterious marine ecosystem hidden beneath an Antarctic ice shelf An international team of scientists heads to Antarctica this week (4 February 2019) to investigate a mysterious marine ecosystem that's been hidden beneath an Antarctic ice shelf for up to 120,000 years. Posted on 7 Feb 2019
Scientists drill to record depths in Antarctica
Team drilled over two kilometres through the ice sheet using hot water A team of scientists and engineers has for the first time successfully drilled over two kilometres through the ice sheet in West Antarctica using hot water. This research will help understand how the region will respond to a warming climate. Posted on 27 Jan 2019
Melt-rate of West Antarctic Ice Sheet
Melting of ice shelves is far more variable than previously thought Scientists studying seawater temperatures in the Amundsen Sea – part of the West Antarctic Ice Sheet (WAIS) – found a cycle of warming and cooling in the ocean over the 16 years of their observations. Posted on 19 Aug 2018
Major shift in marine life
Occurred 33 million years later that thought A new study of marine fossils from Antarctica, Australia, New Zealand and South America reveals that one of the greatest changes to the evolution of life in our oceans occurred more recently in the Southern Hemisphere than previously thought. Posted on 21 May 2018
Life in the slow lane
Five Antarctic marine invertebrates use less energy to reproduce than their tropical relatives A new study from British Antarctic Survey shows how five common Antarctic marine invertebrates (animals without a backbone) use less energy to feed, grow and reproduce than their temperate and tropical relatives. Posted on 22 Jan 2018
How ocean warming impacts the twilight zone
Ocean warming may have implications for the 'twilight' zone A new study from the British Antarctic Survey shows how lanternfish, small bioluminescent fish, are likely to respond to the warming of the Southern Ocean. Posted on 15 Jan 2018
Cyclops Marine 2023 November - FOOTERPantaenius 2022 - SAIL FOOTER - ROWMarine Products Direct 2023 - Calypso FOOTER
