Feb-Nov23 Leaderboard TEMO2
Shimano Bantam A delivers power, precision and performance
by Shimano 2 Oct 2022 16:23 UTC
Shimano Bantam A © Shimano
Shimano introduced the first Bantam reel more than 40 years ago and continues to fuel the fire of elite bass anglers with the release of the revamped Bantam A.
This low-profile baitcasting reel was precision engineered from concept to completion, delivering unrivaled power so anglers can target heavy cover with ease and efficiency. Equipped with features and technologies never seen on a low-profile baitcasting reel, the redesigned Bantam is the pinnacle of Shimano reel engineering.
The redesigned Bantam A provides anglers with unsurpassed cranking power with Shimano's Infinity Drive technology. Shimano engineers specifically designed the new Bantam to attack thick vegetation, flip jigs, burn spinnerbaits and scour the depths with large crankbaits. Thanks to Infinity Drive, Bantam A delivers decreased torque under load, making reeling easier when battling trophy fish or presenting big baits.
Shimano engineered the new Bantam A for the toughest angling assignments. Shimano's exclusive cold-forged HAGANE Gear is at the heart of every Bantam A, leveraging high-precision gears with micron tolerances to ensure an ultra-smooth feel and reliable functionality season after season. Bantam's CoreSolid Body integrates the B-Side Plate, levelwind guard and frame into a solid one-piece construction that delivers confidence and power through unparalleled rigidity and enhanced gear meshing. Furthering super smooth rotation of the spool and handle, MicroModule Gear delivers the perfect retrieve with an entirely new gear set that uses smaller teeth and more of them. This provides additional contact points between the pinion and drive gears for a more efficient gear train. Together, these celebrated Shimano gear technologies enable bass anglers to improve performance and increase efficiency for a stronger and more enjoyable experience.
Helping cast lures a county-mile, the Bantam now features Shimano's MGL III Spool to yield significantly reduced startup inertia, allowing anglers to reach distant targets while providing the added versatility to fish a variety of baits and presentations. The narrow spool design allows for accurate presentations of lightweight baits but also makes casting bigger baits better.
By applying slight pressure to the bearing holding the spool, SilentTune reduces the vibration of the bearing during high-speed rotation. This improves upon the reel's quietness while casting. Furthering the precision line management of the Bantam A, SVS Infinity provides easy-to-manage, consistent spool control, and brake force. With brake weights that use inner friction against the raceway, SVS Infinity allows for quick, precise adjustments when anglers need to adjust to new baits and changing conditions.
The new Bantam A is available in three models to suit every bass angler around the country, each with the capacity for 150 yards of 20-pound test PowerPro and up to 120 yards of 100-pound-test monofilament. Handling a variety of techniques and presentations, like working thick cover with a squarebill or launching shallow-running spinnerbaits to the horizon, the BANTAM150A features a 6.2:1 gear ratio and retrieves 27 inches per crank.
The Bantam BANTAM150HGA has a 7.1:1 gear ratio, retrieves 31 inches per crank, and is a perfect choice when fishing bottom contact baits like a jighead, Texas or Carolina rig. The BANTAM150XGA with its 8.1:1 gear ratio retrieves line at a blazing fast 35 inches per crank, which is a huge benefit when frogging, punching and pitching, and quickly picking up slack when enticing bass on topwater baits. Each model is finely tuned to present and retrieve baits with maximum efficiency and is available in left and right-hand retrieve.
A reel with a reputation for being super tough and powerful is now stronger and more versatile than ever before. Step up your game with the next generation of Bantam A reels available at authorized Shimano retailers, with MSRP of $349.99.
Bantam A features:
  • CoreSolid Body
  • Infinity Drive
  • MGL Spool III
  • MicroModule Gear
  • HAGANE Body
  • SilentTune
  • SVS Infinity
  • S-ARB
  • Super Free Spool
  • Cross Carbon Drag
New look and feel for MyBoat
GJW Direct's boating organiser is great for managing your boat-related admin MyBoat takes the hassle out of sailing and leaves you more time to enjoy life on the water. Plus, all GJW Direct policyholders automatically get access to discounts on top marine brands, via the MyBoat website. Posted on 18 May
Introducing the IP-M60
The World's First* LTE & VHF Marine Hybrid Transceiver Designed to meet the evolving needs of maritime professionals, the IP-M60 combines the reliability of traditional VHF communications with the versatility of 4G LTE connectivity providing users with communication covering both land & at sea. Posted on 17 May
Loads of amenity - Goes like a cut cat
As the first Cure 55 steps closer to being splashed it looked more like a Purosangue to me As the first Cure 55 steps ever closer to being splashed, I could not help thinking that it was a lot like the Ferrari Purosangue. More space than your typical two-seat hypercar, yet with the punch to dispatch distances and pretenders with complete ease. Posted on 16 May
World ARC 2024-25 - Leg 5 departs Bora Bora
The small South Pacific island of Niue is the next port of call For their next port of call, to the small South Pacific island of Niue, the World ARC fleet divides into two groups. Posted on 16 May
World ARC 2024-25 - Beautiful Bora Bora
The Pearl of the Pacific When you take in the iconic and striking mountainous backdrop, coupled with a mesmerising lagoon and an array of white-sand beaches, it's easy to see why Bora Bora is nicknamed "the Pearl of the Pacific". Posted on 16 May
David, Jean-Pierre and Béatrice aboard Excess 14
Follow the adventures of catamaran enthusiasts! In the second video of the series, you will meet David, our experienced skipper and Tahiti dealer, aboard Jean-Pierre and Béatrice's Excess 14! Posted on 16 May
Rapid progress on wallywind110 and wallyrocket51
2024 will be a milestone year for Wally's sailing division Excitement is growing at Wally as work nears completion on two exceptional sailing boats, as different from each other as night and day. Posted on 15 May
Ancasta to present stellar lineup
World-leading brands set for British Motor Yacht Show in Southampton The renowned yacht brokerage firm Ancasta is thrilled to be showcasing a stellar line-up of yachts from a selection of world-leading brands at this year's British Motor Yacht Show, taking place at Southampton's Swanwick marina on the UK's South Coast. Posted on 15 May
ARC Europe 2024 is arriving in Bermuda
The first boat due to arrive on the docks in St George's Harbour on 16 May ARC Europe 2024 is arriving on the beautiful island of Bermuda! 18 out of the 34 boats in the fleet are on their way from St Maarten (Leg 1), with the first boat due to arrive on the docks in St George's Harbour on 16 May. Posted on 15 May
NOAA partners with U.K. anglers and scientists
Study to focus on movement ecology of blue sharks in the eastern North Atlantic NOAA shark researchers are kicking off an international science initiative this month to tag up to 2,000 mature blue sharks off the coast of the United Kingdom. Posted on 14 May
Hyde Sails 2022 One Design FOOTERCyclops Marine 2023 November - FOOTERPantaenius 2022 - SAIL FOOTER - ROW
