Season change means it's time to check shore power gear
by Martin Flory Group 30 Jan 2021 00:20 UTC
Hubbell Marine 50A, 125V Twist-Lock® Cable Set © Martin Flory Group
Periodically checking shore power equipment is an important maintenance task, whether the boat owner is preparing for spring commissioning or organizing for fall storage. If a cord set shows damage, it should be replaced. The Hubbell Marine 50A, 125V Twist-Lock® Cable Set offers a durable choice. Built for continuous use, it incorporates safety and convenience features that overshadow competing products.
Made in the USA, the fully encased Hubbell 50A Cable Set has ergonomic styling with line-up notches that make plugging-in simple. Its nickel-plated brass blades and shell, plus a stainless steel threaded sealing ring, ensure a positive and safe connection and watertight seal. With 3-pole 4-wire grounding, the connector has an exclusive internal copper crimp barrel termination for protection against overheating and burnout. Models are offered with high-intensity green and red LEDs built into the male end that indicate power is flowing or incorrect wiring is detected.
When checking the cable set, first make sure it's unplugged at both ends. Look for bent or corroded blades. Brown on the plug means it's overheating from resistance and/or arcing. These serious safety issues require immediate replacement of the unit. If everything looks okay, a quick cleaning and dab of dielectric grease on the blades are all that's needed to put it back into service.
Unlike many cord sets, Hubbell's is incredibly flexible due to jute fillers inside the heavy-duty jacket. This allows it to coil easily and lay flat. 50A Cable Sets are available in yellow or white and are offered in 7.6m and 15.2m lengths.
Dirt and grime are easily cleaned off cord sets using acetone, but cuts and acute kinks shouldn't be ignored. If damaged cable is close to either the boatside or pedestal plug, it can be cut off and the connector reinstalled with a new boot. Otherwise, users should skip the dangerous temptation to patch with electrical tape and instead replace the cord set.
Hubbell Marine's 50A, 125V Twist-Lock® Cable Set is CL and cUL listed. It meets USCG requirements and has ABYC approval.
For more information contact Hubbell Marine Tel: +1-727-304-7638 and /or visit www.hubbell-marine.com.
Hubbell isolation transformers increase safety
One of the great joys of boating is the freedom to explore distant shores One of the great joys of boating is the freedom to explore distant shores. But the availability of clean, safe dockside power at remote ports of call can never be guaranteed. Posted on 22 Sep 2023
Advanced Y Adapter aids safe dockside connections
Allowing owners to easily correct 30A and 50A connection mismatches Cruising boaters visiting new destinations can face challenges when the marina's shorepower system differs from that of the boat. Posted on 14 Sep 2022
Y-Adapter gives cruisers electrical peace of mind
Enabling powering a 100A vessel from two 50A receptacles dockside Serious cruising boaters know that the most interesting ports of call are often served by smaller marinas, which may not offer amenities like 100A service. Posted on 7 May 2022
Connectors for boating without borders
Shore power systems can vary greatly from one country to the next Shore power systems can vary greatly from one country to the next, posing challenges for cruising boats worldwide. Internationally-rated connectors from Hubbell Marine allow these vessels to enjoy compatibility abroad for safe and reliable power anywhere. Posted on 1 Apr 2021
Hubbell Intelligent Y Adapter keeps the lights on
Automatically checks that both plugs are engaged and in separately-phased outlets Owners whose boats have 50A 125/250V electrical systems will spend the night in the dark if they cruise to a marina that only offers 30A 125V service. Posted on 26 Feb 2021
Intelligent Adapter corrects shore power mismatch
The YQ100PLUS adapter from Hubbell Marine offers a solution While a growing number of boats operate on 100A electrical systems, many marinas are still in the process of upgrading power pedestals to accommodate them. The YQ100PLUS adapter from Hubbell Marine offers a solution. Posted on 1 Apr 2020
Noble Marine 2022 SW - FOOTERCyclops Marine 2023 November - FOOTERHyde Sails 2022 One Design FOOTER
