Barton Marine 2019 728x90
Solaris 40 - Top entry level
by Solaris Yachts 16 Sep 2021 23:39 UTC
Solaris 40 © Solaris Yachts
The new Solaris 40 contains in its 12.36 meters the result of an intense design study, signed by the Solaris designer Javier Soto Acebal and with features that characterize this new project in terms of hull performance and navigation comfort.
The goal was to be able to equip a 40-foot boat with all the innovations that characterize higher-end models.
Evolution at any level
Solaris 40 has the new type of lines with a lot of emphasis on general balance, static and dynamic. For the static balance, great attention was paid to the distribution of weight under the water, to the thrust center, to the position of the keel to adequately counteract the forces of the sail, to the position of the rudder, etc.
For the dynamic aspect, the design focuses on real-life sailing situations, good all-round properties, stability under different heel angles, bow trim, coefficients and performance relationships with the expected range of trim and heel combinations.
Solaris 40, advances towards evolution and progress, thoroughly analyzing each new improvement, not only aspects of the waterlines, but also the many practical issues that must be carefully integrated into the design process.
News and trends
  • moving the mast backwards, increasing genoas and gennakers areas.
  • balancing with longer waterlines at design trim, with center of buoyancy and keel going backwards too, thus allowing the keel to match the mast properly and boat center of gravity.
  • rudders with increased aspect ratio, and foils cross sections have the center of pressure moved forward, delaying the stall angle. Rudder tips are becoming square type, very powerful on the deeper zones.
  • keel is aggressively designed to lower the center of gravity, using all the Javier Soto Acebal racing boats developments. Foils and bulbs are properly designed to each new local Reynolds number (relative speeds at the appendage).
  • deck beam has been progressively increased at the stern, to finally arrive to have almost max beam hold constant up to the transom.
  • overall hull shaping is showing more volume on the extremes and a reduced master section (less beam on the waterline and local hull draft), so hulls are looking slenderer.
  • prismatic overall hull coefficient, increased. The added volume on the bow is helping to balance the new powerful sterns. This new shape has higher form stability and much more potentiality for achieving higher speeds.
  • transom have become more vertical and with less cross curvature, so under heeling not an inch of effective sailing length is lost.
  • shape of the stern zone has evolved towards shorter overhangs, that must be carefully attended, to overcome drag under slow speeds (added wetted surface and eddies)
  • sheerline is totally straight if seen from a perfect lateral point of view.
  • sheer height and shape has a second effect on cabin aesthetics, determining its final height and lower curvature at its deck camber intersection
  • delation of the decorative cove stripe was taken on all new models, in my opinion makes a much more modern look and pure aspect overall
Spaces of a larger boat
Solaris 40 has a space between the two binnacles that is not found even on boats over 100 feet. This allows the helmsman to steer without being limited by the size of the sprayhood, always having the leech edge and the jib fillets clearly visible. Two folding seats let the helmsman to maneuver and steer also while seated. The exit from the cockpit is very convenient. A space has been obtained and exploited specially designed to allow an easy passage with two steps to climb the side decks, from which the slanted handrails at the stern start.
The distance between the two steering wheels also increases the livability of the cockpit, which reaches maximum and unique levels for a 40-footer, and enhances its usability.
Wide spaces
The interiors, created with the contribution of Patrick Roseo, architect, thanks to the shapes of the hull, are the largest in the category and offer an innovative design.
Two layouts available: three cabins and two bathrooms or two cabins and two bathrooms, with separate shower. The interior design is extremely refined and of high quality, with the cabinets that contain the six hull windows. The layout is classic with an L-shaped kitchen to the left of the entrance.
Either by choosing the version with three cabins and two bathrooms, or by opting for the version with two cabins and two bathrooms, Solaris 40 offers large storage space.
The comfort details are particularly studied. The wardrobe in the owner's cabin, for example, is equipped with several customizable shelves, and a space for long dresses. The owner's cabin is full-height for its entire volume with lots of space, a solution that is not found on a 40-footer.
Solaris Yachts: since 1974 conceived, designed and built for sailors
Tech specs
  • LOA 12.36 m
  • LWL 11.70 m
  • Beam 4.10 m
  • Draught 2.40 m (2.00 m optional)
  • Displacement 9,400 Kg
  • Ballast 3,050 Kg
  • Power 30 - 50 - 6 HP
  • Fresh water 350 l
  • Fuel 200 l
  • Certification CE Rina
  • Sail area 100 - m2 std
  • Genoa 43 - m2 std
  • Mainsail 57 - m2 std
  • I 16.80 m
  • P 16.40 m
  • E 5.75 m
  • J 4.70 m
New Solaris 74 development in its final stages
The only raised saloon with sleek lines and pace of a performance cruiser The development of the new Solaris 74 is at its final stages. T Posted on 9 Apr 2023
New Solaris 74 RS construction update
A bluewater yacht that embodies the innovation and savoir-faire We close 2022 by realising something that so far was only a project, our new Solaris 74 RS, a bluewater yacht that embodies the innovation and the savoir-faire typical of Solaris, able to satisfy the needs and the ambitions of every owner. Posted on 19 Dec 2022
Solaris Yachts get set for boot Düsseldorf 2022
Representing the most important meeting point with our owners We are getting ready for the Dusseldorf Boat Show. This event represents the most important meeting point with our owners. Since this is the only indoor boat show Posted on 8 Nov 2021
Solaris 60 - the trendy mini-maxi
Representing the latest design expression by Javier Soto Acebal They are very solid, safe and comfortable boats. The shipyard uses the most advanced technologies in their construction, and the most traditional craftsmanship in details and finishing. Posted on 22 Sep 2021
Virtual visit of the new Solaris 60
The result of an intensive and careful study of real needs There is a delicate balance between performance and pleasure. A fast line with a technical and empathetic trait represents the style of the boat: innate elegance. Posted on 26 Dec 2020
Solaris Yachts 2020 latest - Solaris 40 and 60
The first 40 hull is about to be completed with several hulls sold already This 40 feet boat will mark the history of the yard and she will represent a benchmark for the market, thanks to her innovative design and also to the many solutions conceived for a boat of these dimensions. Posted on 6 Dec 2020
Solaris Yachts 2020 Latest - Solaris 40 and 60
These two new performance cruisers are close to launch These two new performance cruisers are close to the launch. Thanks to the many innovations, they are going to redefine once more the standards in their category. Posted on 19 Sep 2020
Solaris 80RS Altihia: Simplicity and substance
First of the new model sails into Mediterranean waters Time flies and summer has just arrived. We are making every effort not to disappoint your expectations. To this matter, we want to share with you the emotion exhaled from the view of the first model of the Solaris 80RS sailing into the Mediterranean. Posted on 5 Jul 2020
Solaris 80RS has been introduced
An important milestone for Solaris Yachts We are very proud of the launch of the first Solaris 80RS, an important milestone for Solaris Yachts. Fast performance and innovative design are the main features of this yacht. Posted on 26 May 2020
New Solaris 80RS set to be launched soon
The latest evolution of more than 30 years of Solaris experience We are almost in the final stages of this incredible project. We invite you to read again the technological content of this new yacht before performing the first exciting test at sea. Posted on 5 May 2020
Cyclops Marine 2023 November - FOOTERNorth Sails Performance 2023 - FOOTER2024 fill-in (bottom)
