Loose grub screw apparently the problem on Dutch ARC yacht rudder case
by X-Yachts 22 Feb 2022 14:18 UTC
ARC X4? rudder case © X-Yachts
A loose grub screw was apparently the reason why a Dutch owner of an X49 in January experienced difficulties when taking part in the transatlantic race "ARC January". X-Yachts' Director of Design & Engineering, Thomas Mielec, met the boat on Gran Canaria after the boat had been salvaged.
During the race "ARC January", the rudder stock fell out of the top bearing of a Dutch-owned X49. In addition to the loss of the steering, this meant that the movement of the rudder stock damaged the GRP tube, which encapsulates the bottom bearing and forms a water seal towards the inside of the boat. The crew contacted X-Yachts Holland via satellite phone for guidance in resolving the issue.
The crew were unfortunately unsuccessful in their attempts to reinsert the rudder stock into the top bearing and were only able to partially secure the top of the rudder stock in position by provisional means. They did, however, manage to steady the water ingress to a level where the bilge pump could keep up. However, the crew was so insecure about the situation and its potential to worsen that the next day they chose to evacuate the boat and board two other yachts, which were attending the race.
Two days after the evacuation, the boat's insurance company entered with a salvage company, who, using the boat's tracker, found the boat afloat 4 days later. The generator had stopped, but the bilge pump was running and the water level in the boat was still below floorboard level.
The salvage crew got the rudder stock in place and secured in the top rudder bearing relatively quickly, and they had the leak repaired and the water pumped out, after which they could tow the boat towards Gran Canaria approx. 1400 nautical miles sailing from there.
X-Yachts' Director of Design & Engineering, Thomas Mielec, was, together with people from the salvage company and the involved insurance companies, ready to meet them and by joint efforts to identify the cause of the damage:
"The crew from the boat took photos and video in their attempt to repair the rudder, and it appeared that the top bearing had separated, and the rudder stock had dropped down. The rudder bearing union nut, which holds the bearing together, had simply turned off the thread at the bottom of the inner housing, and this meant that the rudder and rudder stock, which are otherwise fixed in the bearing, had dropped downwards and out of the bearing."
"This happened even though the locking screw was in place in the union nut, and that with only one impression mark, i.e. without traces or burrs, which could indicate that the union nut had been turned off with the locking screw engaged. The other parts of the bearing showed no signs of overload prior to the incident in general."
It is still too early to draw a conclusion of the definitive cause of the damage, but Thomas Mielec assesses two possible scenarios based on the facts and observations found:
  1. If it is established that there is no trace of Loctite on the locking screw, one possible scenario is, that in error, the locking screw was never secured with Loctite during manufacture of the bearing, and that the screw, without being noticed, had loosened over a period of two years, permitting the nut to also unscrew over time.
  2. If tests show that there were traces of Loctite in an expected amount on the locking screw, the cause could be that the safety screw had been removed / loosened by mistake during service work, which was carried out in Spain in November.
Thomas Mielec assesses scenario 2 as the seemingly most likely.
The locking screw in question is only intended to be operated during the manufacturing of the bearing itself, and it is not necessary / permitted to touch during either assembly or possibly disassembly of the rudder in the yacht.
XR 41 hull plug in the making!
Get an exclusive behind-the-scenes look at the making of the XR 41 Get an exclusive behind-the-scenes look at the making of the XR 41, as the hull plug is being CNC machined with high precision and expertise at Nedcam in Holland. Posted on 1 May
X-Yachts Australia Newsletter - April 2024
XS Moment (an Xp 44) takes Line Honours in the Pittwater to Coffs 28 yachts set off on the 226 nautical mile CAT 3 race from Pittwater to Coffs - just three finished. We are proud to report that XS Moment (an Xp 44) took Line Honours in Ray Hudson, the Owner/Skipper proudest moments in his illustrious sailing career. Posted on 28 Mar
Lots of interest for electric propulsion
4,500 visitors saw the Xc 47 with electric propulsion at Boot Düsseldorf 4,500 visitors saw the Xc 47 with electric propulsion at Boot Düsseldorf, many of whom have now contacted the yard for more information. Posted on 1 Mar
Complete walkthrough of the new Xc 47
Torben Kornum guides you through the exterior and interior features Are you curious about all the great features in the new Xc 47? Posted on 22 Dec 2023
X-Yachts Aurum Cup 2024 announced
To be held from Middle Harbour Yacht Club on the 21st & 22nd June X-Yachts Australia is pleased to announce the inaugural X-Yachts Aurum Cup to be held from Middle Harbour Yacht Club on the 21st & 22nd June 2024. Posted on 19 Oct 2023
X-Yachts introduces a newly improved X4.9!
New look with an updated hull, new rudder, lower weight and more luxury in the cabin X-Yachts introduces a new X4.9 with a lot of improvements - new look with an updated hull, new rudder, lower weight, more luxury in the cabin - and better performance too. Posted on 26 Sep 2023
Xc47 nominated for European Yacht of the Year 2024
The Xc47 is going through test sails in Barcelona in October The Xc47 has been nominated for European Yacht of the Year 2024! A 12 person jury voted for the Xc47 to be among the finalists for the European Yacht of the Year. Posted on 4 Sep 2023
X-Yachts presents new XR model in Kiel
The first sketches and thoughts were presented in front of racers taking part in the ORC Worlds X-Yachts revealed plans for the most dedicated racing project for decades. The first sketches and thoughts were presented in front of racers and media taking part in the ORC Worlds in Kiel. Posted on 14 Aug 2023
Introducing the new X4.9 Mk II
X-Yachts introduces a new X4.9 with a lot of improvements X-Yachts introduces a new X4.9 with a lot of improvements - new look with an updated hull, new rudder, lower weight, more luxury in the cabin - and better performance too. Posted on 3 Aug 2023
XC 47 build no. 1 hybrid
Increasing focus on sustainability and demands from our clients Based on the experiences with the X47E, the increasing focus on sustainability and demands from our clients, X-Yachts has decided to build the first Xc 47 as a hybrid yacht. Posted on 3 Jul 2023
