Leaderboard brokerage
Ronstan blocks for dredge and outrigger set up
by Ronstan 29 Apr 2022 04:41 UTC
Smooth running (especially for monfilamnet) and low maintenance with Ronstan blocks for dredges and outriggers © Ronstan
Upgrading your outrigger hardware with Ronstan blocks is the easiest and most effective way to improve the performance of your dredge and outrigger setup.
• Reduced wear on halyards and monofilament lines caused by outrigger eyes
• Smoother and easier to deploy and retrieve your dredge
• Reduced stress on rods and outriggers.
The easy rolling action Ronstan outrigger pulleys provide is the result of a sophisticated two-stage bearing system, allowing them to remain highly efficient across the entire working load range.
A recessed sheave prevents the running line from jumping the pulley wheel and becoming jammed in the side plates.
Pantaenius 2022 - SAIL FOOTER - ROWOcean Safety 2023 - New Identity - FOOTERCure Marine - Cure 55 - FOOTER
