Gill Graduate National Championship 2022 at Grafham Water Sailing Club
by Bob Murrell 12 Jul 2022 05:09 UTC 9-10 July 2022
Day 1
Race 1
With the wind about force 2 gusting 3, coming almost from the North, the race officer Nigel Denchfield set a sausage triangle sausage course from the clubhouse side of the lake. The Herons were sharing the event and set off first, the Grads 4 minutes later (3,2,1 start sequence). The breeze dropped a little just before the start and John Clementson opted for the port end of the line, the bulk of the fleet congregating nearer the committee boat. The lighter conditions meant the Grad fleet overhauled most of the Herons before the windward mark. The early leading pack included Richard and Jane Thorpe, Fresh Abendstern & Ross Southwell and John Clementson and Mel Titmus. Sam McKay and Jack Cammonn were in the top 5 with Tim Hand and Dave Moore also in the mix. As the fleet completed the first of the triangular section Fresh was leading with John in close contention and Tim Hand staying in touch, Sam just behind. As the breeze settled back to a steadier 2 but with some holes the leading 4 pulled clear, Fresh & Ross taking line honours, John & Mel second and Sam & Jack in third.
Race 2
In between the races the breeze filled in only to drop as the starting sequence began for the second race of the day. With the drop in pressure the direction also shifted to the West making the port end of the line the favourable side. Sam & Jack, John & Mel and Tim & Dave made their way there only for Sam to be OCS right on the pin meaning a "round the ends" for him. John & Mel and Tim & Dave made good their starts with Sam & Jack close behind. The westward shift lasted for most the first half of the first beat before swinging back to the North allowing the Grad fleet to get through the Herons fairly early.
The run was very competitive with 5 Grads making multiple gybes to try to gain an advantage, all rounding the leeward mark within a few seconds of each other although Sam & Jack had fallen back in to the middle of the fleet. The wind eased for the back markers making it a drift around the leeward mark for them. The second beat saw the wind shift to the Northeast making the starboard tack dominant. The leading pair broke away, Tim & Dave rounding the leeward mark closely followed by Richard & Jane Thorpe, John & Mel in 3rd and Fresh & Ross in 4th place. With the breeze freshening Tim & Dave stayed in the lead, Richard & Jane taking second followed by John & Mel.
Race 3
Midday and the wind died. With a postponement the fleets waited for the breeze to fill back in. After a 10 minutes delay the third race got under way with one team OCS. The Grads favoured the right side of the race course, the Herons the left. At the windward mark the fleets converged, Fresh & Dave coming out in the lead closed followed by Tim & Dave, John & Mel and then Sam & Jack with James Webber & Helen Recardo not far behind. Bryn Abendstern & Ruby Barber fought through to 5th in the latter part of the first run.
The windward mark saw Fresh in the lead, Tim in second and Victoria Theaker & Lewis Coppinger moving up to 3rd, then John, Bryn and James in that order close behind. Clive Herd & Natalia Zin-Safianowicz were having the best race of their afternoon but the whole fleet was close together.
At the end of the second run, Fresh and Ross were still leading but there was nothing between the following 6 boats. Tim & Dave took a wide course, gybing for the mark. Fresh and Ross took line honours with a big lead and, as the wind continued to die, Tim came home 2nd, John 3rd, Victoria 4th, Bryn & Ruby 5th and James & Helen 6th.
Race 4
As had been the pattern for the early races the wind came and went, managing to fill in as the fleet got away, this time cleanly. The leading Grads soon overhauled the Herons, apart from Dave Butler, by the windward mark. Fresh popped out in front with Tim, John and Sam close behind. The whole fleet was quite bunched down the first run which was truer in this race than the third one. Fresh & Ross were leading into the leeward mark closely followed by Tim then John and then Sam.
Approaching the wing mark Fresh was narrowly in lead from James & Helen who had found form on the second beat, John & Mel lying in 3rd, Tim in 4th and Sam 5th. Fresh stayed in the lead with John finding a way past James as they rounded the mark. Clive & Natalia and Hamilton Roaf & Grace Everett were both having the best race their afternoons in 7th & 8th. By the leeward mark the top 8 boats had closed right up together behind Fresh, John and James in that order, Tim and Sam immediately behind.
After the windward mark John & Mel were close to Fresh & Ross with James & Helen still holding off Tim & Dave. However, Fresh & Ross managed to stay in the lead by the line for his 3rd bullet of the day, John & Mel were second with Sam & Jack third and Tim & Dave in fourth. James and Helen had an excellent result coming in fifth.
Day 2
Race 5
We awoke to virtually flat calm giving beautiful views across the lake, the opposite bank and trees perfectly reflected in the still water. Not so good for racing though.
The race officer held the briefing as arranged explaining how the fleets would integrate with the standard Sunday club starts.
In the event, there were only a couple of club single handlers who ventured on to the water and the combined Heron and Graduate fleets had the last start of the normal club race start sequence. There had been some discussion about delaying the start but the consensus was to stick with the original timings. This was just as well as although there was some breeze for the gun at 11.20 the light breeze gradually died as the fleet crept around the windward / leeward course. Fresh and Ross eked out a small lead followed by John & Mel and then Tim & Dave. These positions were unchanged at the line with Richard & Jane scoring a fourth and Victoria & Lewis maintaining their form in fifth.
As the conditions deteriorated further the race officer decided there was insufficient wind to run a sixth race and so the fleet rocked and rolled back to the shore for the conclusion of the weekend.
The Graduate Dinghy Association is very grateful to Grafham Water SC for organising and hosting a really successful event. We would like to thank Nigel Denchfield and his race team plus Lisa and her catering colleagues for looking after us so well on and off the water and Gill for their very generous sponsorship of the prizes and the event.
Overall Results:
If you finished in the top ten at the Graduate nationals then enter your Gear Guide information here
PosSail NoHelmCrewSailingClubR1R2R3R4R5Pts
1st3013Richard Fresh AbendsternRoss SouthwellToddbrook SC1‑41114
2nd3009John ClementsonMelanie TitmusChipstead SC2‑33229
3rd3001Tim HandDave MooreSwarkestone SC‑4124310
4th2873Sam McKayJack CammannSwarkstone3773‑1020
5th2750Victoria TheakerLewis Lupton CoppingerToddbrook SC5‑846520
6th3004Richard ThorpeJane ThorpeToddbrook SC82‑98422
7th3015James WebberHelen RecardoChipstead SC6565‑822
8th3020Bryn AbendsternRuby BarberToddbrook SC‑7657725
9th2531Patrick HillJonathan HillSwarkestone SC‑109810633
10th3008Ric LewisJohn HighamChipstead SC910‑119937
11th2952Clive HerdNatalia Zin‑SafianowiczWelland YC1111‑12111245
12th2901Hamilton RoafGrace EverittShustoke SC‑131310121348
13th3024Christine DawberJacqueline KamauDale YC1212‑13131148
Guy Fawkes Pursuit Race at Leigh & Lowton
It's a Graduate 1, 2 Leigh & Lowton SC kicked off their winter programme with their traditional Guy Fawkes Pursuit, this year on Guy Fawkes night itself, so there was Mulled Wine, Parkin Cake and Treacle Toffee available by a roaring fire after prize-giving. Posted on 11 Nov 2023
Craftinsure Bass Week 2023
230 entries, the biggest in the last 10 years Craftinsure Bass Week 2023 was a big one, with 230 entries, the biggest in the last 10 years. The club grounds were expertly prepared for the onslaught when the gates opened at 9am on Friday 5th August. Posted on 15 Aug 2023
Graduate Northerns at Bassenthwaite
Held over the first weekend of Bass Week A select group of eight Grads entered the Graduate Northern Championships which were held over the first weekend of Bass Week. Posted on 13 Aug 2023
Graduate Nationals at Northampton overall
Starting with Pitsford reservoir looking distinctly holey! Overnight results were tight, and as Sunday dawned it looked like it was going to be another light wind day, with Pitsford reservoir looking distinctly holey! Posted on 19 Jun 2023
Graduate Nationals at Northampton Day 1
Waking up to a swinging 3-5 knots of breeze on Saturday morning After a day of sunbathing, tweaking rig setups, and getting some last minute practice in on the Friday training day, the Grad fleet awoke to a swinging 3-5 knots of breeze on Saturday morning. Posted on 17 Jun 2023
Graduate Nationals runners and riders
Who could be the fastest pairings at Northampton next weekend? This year the Grads are heading to Northampton on the 16th-18th June for our National Championships. With 15 boats currently entered, and entry still open for anyone with FOMO, it's set to be a cracking weekend at Pitsford reservoir! Posted on 12 Jun 2023
Graduate Southerns at Chipstead
A twenty strong fleet race on the Sunday and Monday of the Coronation weekend A twenty strong fleet of Graduates attended the two day event, shared with the Heron Nationals, held on the Sunday and Monday of the Coronation weekend, taking advantage of the extra bank holiday Monday, with 5 visitors joining 15 home boats. Posted on 10 May 2023
Derbyshire Youth Sailing event at Burton
Season opener for 21 boats enjoys gentle breeze, unlike last year This year's Derbyshire Youth Sailing (DYS) handicap series got off to a flying start with the season opener at Burton Sailing Club on Saturday 22nd April. The weather was perfect, to ease the competitors into the new season, with a gentle breeze. Posted on 26 Apr 2023
Graduate Southern Championship preview
Chipstead will welcome fleet on May bank holiday weekend Chipstead Sailing Club welcomes entries to the Graduate open meeting and Southern Championships, which is taking place over 1.5 days on Sunday 7 May 2023 and Bank Holiday Monday 8 May 2023. Posted on 14 Apr 2023
Battle of the Hikers preview
No trapeze? Get to Rutland this May! The very popular Battle of the Hikers will take place on the 27th and 28th May 2023. 30+ boats are expected. The Graduates were the biggest class last time. Nick Craig sailing his OK was the overall winner. Posted on 18 Mar 2023
Ocean Safety 2023 - New Identity - FOOTERPantaenius 2022 - SAIL & POWER 1 FOOTER ROWCure Marine - Cure 55 - FOOTER
